Belkin OmniView Soho Series 4-Port USB Dual Headed KVM
Quicklinx: 6KBBWS00 Mfr#: F1DH104LEA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
£147.60 ex VAT
£177.12 inc VAT
The Belkin SOHO Dual Monitor Desktop KVM Switch lets you share up to two monitors, keyboard, and mouse with up to four computers, saving space on your desk and reducing equipment clutter. The sleek, new design incorporates a built-in USB 2.0 2-port hub with one of the ports conveniently located on the front. This is perfect for connecting an MP3 player, printer, scanner, or any of your USB devices to the KVM Switch while allowing your connected computers to access them. Sensitive push buttons on the front allow for easy switching, and independent audio-switching means you can play music from one computer while accessing files from another.
Belkin OmniView SOHO Series 4 Port KVM Switch with Audio - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
DC 9 V
31.8 cm x 14 cm x 14 cm
0.7 kg
3-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Status Indicators
Port status
8 x VGA HD-15 , 4 x microphone mini-jack , 4 x headphones mini-jack , 2 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 2 x USB Type A , 1 x microphone mini-jack , 1 x headphones mini-jack
External power adapter
DC 9 V
4 x USB cable kit - 1.8 m
31.8 cm
14 cm
14 cm
0.7 kg
Limited warranty - 3 years
0 - 80%
6KBB C2G 2m 3.5mm M/M Stereo Audio Cable In Stock £4.29
6KBB C2G 3.5mm Stereo Male to Dual 3.5mm Stereo Female Adapter In Stock £4.42
6KBB C2G 3m 3.5mm M/M Stereo Audio Cable In Stock £4.46
6KBB C2G 2m 3.5mm M/F Stereo Audio Extension Cable In Stock £4.02
6KBB C2G 5m Velocity™ 3.5mm M/M Stereo Audio Cable In Stock £6.89
6KBB C2G 6.3MM STEREO MALE TO 3.5MM STEREO FEMALE In Stock £4.42
6KBB C2G 10m Velocity™ 3.5mm M/M Stereo Audio Cable In Stock £11.02
6KBB C2G 3.5mm Stereo Male to 6.3mm Stereo Female Adapter In Stock £4.27
Connectivity: KVM
Ports: 4
Brand: Belkin
Price Range Ex VAT: 100 - 150
