The OmniView PRO3 USB and PS/2 KVM Switch provides easy and dependable server control with extraordinary performance. The Switch enables network administrators to monitor and control up to four, eight, or 16 USB- and PS/2-platform servers from a single console. The PRO Series KVM Switches are the industry's most popular for small to medium server rooms, branch locations, and test and development labs. Designed to grow along with your server network, the Switch can be daisy-chained together using dedicated daisy-chain ports with other OmniView PRO Series or SMB KVM Switches to support up to 256 servers.
Belkin PRO3 KVM Cables are required to connect your servers and computers.
- Belkin OmniView PRO3 USB & PS/2 8-Port KVM Switch - KVM switch - 8 ports - rack-mountable
- KVM switch - 8 ports - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- On-Screen Display, firmware upgradable
- 43.8 cm x 19 cm x 4.5 cm
- 4.2 kg
- Black
- System Requirements
- SunSoft Solaris 8, Novell NetWare 5.x, Microsoft DOS 5.x or later, Apple MacOS X, Microsoft Windows Server 2003, Red Hat Linux 8.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows Vista, Microsoft Windows 7
- 3-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 1920 x 1440 @ 75 Hz
- Status Indicators
- Port status
- 8 x KVM 50 pin Centronics , 2 x network stack device DB-25 , 1 x RJ-11 management , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
- Power Device
- External power adapter
- Black
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- OS Required
- 43.8 cm
- 19 cm
- 4.5 cm
- 4.2 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
