The OmniView PRO3 USB & PS/2 KVM Switch provides easy and dependable server control with extraordinary performance. The Switch enables network administrators to monitor and control up to 4 USB- and PS/2-platform servers from a single console. The PRO Series KVM Switches are the industry's most popular for small-to-medium server rooms, branch locations, and test and development labs. Designed to grow along with your server network, the Switch can be daisy-chained together using dedicated daisy chain ports with other OmniView PRO Series KVM or SMB KVM Switches with DB25 daisy-chain ports to support up to 256 servers.
- Belkin OmniView PRO3 USB & PS/2 4-Port KVM Switch - KVM switch - 4 ports
- KVM switch - 4 ports - stackable
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- On-Screen Display, firmware upgradable
- 27.9 cm x 15 cm x 4.5 cm
- 2.4 kg
- Black
- System Requirements
- SunSoft Solaris 8, Novell NetWare 5.x, Microsoft DOS 5.x or later, Apple MacOS X, Microsoft Windows Server 2003, Red Hat Linux 8.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows Vista, Microsoft Windows 7
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 1920 x 1440 @ 75 Hz
- Status Indicators
- Port status
- 4 x KVM 50 pin Centronics , 2 x network stack device DB-25 , 1 x RJ-11 management , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
- Power Device
- External power adapter
- Black
- Cables Included
- 1 x serial cable
- OS Required
- 27.9 cm
- 15 cm
- 4.5 cm
- 2.4 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
