Belkin Network USB Hub
Customer rating: 5.0* (Write a review)
Quicklinx: 4PPWWS00 Mfr#: F5L009UK
The industry's first reliable print server-3 minute setup. Wireless access to multi-function printers, digital cameras, external hard drives and other USB devices
  • Share printers and multimedia files - wirelessly*
  • With a reliable and easy to set-up built-in printserver
  • Wireless access to printers, USB devices, MP3's, images & more
  • Works with any existing wired or wireless network*
  • Works with all wireless and wired routers
*Network router required - The USB Network Hub stacks with Belkin's N Wireless Router to save space.
Share printers & multimedia files on your network - Connect and access up to 5 USB devices via the Network USB Hub - Share devices such as multifunction printers, media readers and scanners with anyone on your network - Play and transfer music from any external harddrive or MP3 player connected to the Network USB Hub - Back up to and access data from external harddrives, USB flash drives and other USB storage devices - Reliable and easy-to-use print server: the Network USB Hub enables your computer to access printers as if they are directly attached to the computer - Works with any (wired or wireless) router; devices can be accessed from any computer on the network*
FAQs
How does it work?
The Belkin Network USB Hub works by installing software that makes devices appear to be connected directly through each computer's USB ports. Which devices does the Belkin Network USB Hub support?
The Hub is designed specifically for printers and mass-storage devices. It also works for most other USB devices, including most standard webcams, keyboards and mice, multifunction machines, scanners, and media readers. Please note: some high-speed isochronous devices, such as high-definition webcams and video docking stations, may not be compatible with the Hub. How does the Belkin Network USB Hub support multiple users?
The convenience of direct USB-connection emulation requires that only one user be linked to each device at a time. To make this seamless for printers, the Hub automatically disconnects users after sending a print job, so that other users can print. For other devices, the software allows users to contact others on the network to request that they disconnect from a device.
Is the Belkin Network USB Hub compatible with any network?
Yes. However, keep in mind that the quality of the connection of a computer to the devices on the Hub depends upon the speed of the wireless network.
Can I use other USB hubs on the Network USB Hub?
Yes. The Hub allows you to "daisy-chain" other USB hubs. The driver supports a total of 15 connections at a time on the Hub.
How do firewalls impact the Network USB Hub?
If users have the Windows firewall activated, the Network USB Hub will automatically detect this and ask the user if he or she wishes to allow the Hub to work from behind the firewall. Users of other firewalls must manually add the device driver to their list of allowed programs, allowing the Hub to work. Will the Network USB Hub work with a computer on a Virtual Private Network (VPN)? No. The Network USB Hub requires VPNs to be turned off in order for it to function. High-speed isochronous devices (such as high-definition webcams and video docking stations) may not be compatible with the Network USB Hub. *Distance limitation depends on the range of your wireless router
Package Includes - Network USB Hub - Power Supply - RJ45 Ethernet Cable - Quick Installation Guide - Setup Installation CD-rom - User Manual on CD-rom
System Requirements - Microsoft® Windows Vista™ and XP (32-bit) - All computers equipped with WLAN or LAN
Protocol Supported - TCP/IP
Network Standards - IEEE 802.3 10Base-T - IEEE 802.3u 100Base-T
Ports - 1 - 10/100Base-Tx auto-sensing and auto-uplink RJ45 port - 5 - USB2.0 ports - Up to 15 devices can be connected using (an) additional multi-port USB hub(s)
3-Year Warranty
Data-transfer rates do not support some high-speed/high-bandwidth USB devices such as HD-streaming webcams or other video-transfer applications.
  • The Network USB Hub requires an Ethernet connection to a router. Router not included with this product.
Belkin Network USB Hub - device server
Device server
External
United Kingdom
Ports Qty
5
Ethernet, USB, Fast Ethernet
Microsoft Windows Vista / XP
3-year warranty
Device server
United Kingdom
External
Ports Qty
5
Wired
Network / Transport Protocol
TCP/IP
Auto-sensing per device, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u
5 x USB - Type A , 1 x 100Base-TX - RJ-45
1 x network cable
External power adapter
Software Included
Drivers & Utilities
Limited warranty - 3 years
Resources
The following resources are available for the Belkin Network USB Hub
Customer reviews
Write a review for the Belkin Network USB Hub here!
Belkin network USB Hub
Reviewed by Richard McClung. Review Posted 20/01/2008
At last!! A product to share USB devices between PCs with no problems. Thank you sooo much Belkin (and Dabs for their usual speedy delivery!) This really is a joy to have although a few things you should be aware of. 1. The network cable that comes with it is only 2 foot or 61cm long 2. the power lead is only about 3 foot long 3. Install the printer drivers and hub software on each PC before connecting to the hub Minor points for a brilliant product. I would also advise downloading the latest driver for it from the Belkin website.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
... Lemon Squeezy
Reviewed by Colin C.. Review Posted 17/01/2009
Just installed this sweety in our office on 1 PC and two laptops, both connected via docks / ethernet and hooking up 3 shared printers.
HP Deskjet Pro 550
Kyocera KM1635 copier / printer
Dymo label printer (which tends to be a bit tricky to set up)
The thing that took longest was unravelling the maze of USB cables for the printers. Took about 30 minutes in total. Ran first time, no glitches.
TOP TIPS: follow the idiot's guide to the letter, in particular watch for 3rd party firewall instructions during install and choose correct configuration method for sharing / not sharing. Make sure software is on each machine before connecting to the network.
Was a tad pricy but there ain't much in the market to do the job and this does it superbly!
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Excellent purchase
Reviewed by Paul. Review Posted 31/07/2008
Just bought one of these a few days ago and was amazed at the simplicity of the setup. I work in IT and expected I'd have to use some of my IT skills to get things up and running, but no, it was so simple and everything simply worked once the software was installed.
I've a 1TB seagate external drive, an Epson laser printer and an Epson injet printer connected so far and have now access from all 3 computers. Excellent job!
  • Overall 5*
  • Ease of use 5*
Read all 27 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
