Harness the reliability of Ethernet for your USB-C device with the USB-C to Gigabit Ethernet Adapter. Where wireless connectivity is inconsistent, overextended, or even non-existent, this adapter allows you to connect seamlessly and with confidence. With the speed and reliability of Gigabit Ethernet, even the largest downloads can be possible without fear of interruption.
Fast and fearless connectivity
A hard-wired USB-C to Gigabit Ethernet connection provides endurance and speed, wherever wireless is unreliable or inconsistent. -
Belkin tested
With a proven track record in USB-C cables, this Belkin cable has been designed and tested according to our rigorous standards, and comes fully USB-IF certified.
- Belkin USB-C to Gigabit Ethernet Adapter - network adapter - USB-C - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C
- Ports
- Length
- 15 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Black
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB-C
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 x 1000Base-T - RJ-45 - female
- Black
- Length
- 15 cm
- Limited warranty - 2 years
