Belkin Network Adapter - USB-C - Gigabit Ethernet x 1 + USB-C (power only) x 1
Quicklinx: HZKCWS00 Mfr#: INC019btBK
Hurry, only 2 left in stock!
£25.78 ex VAT
£30.93 inc VAT
The Belkin CONNECT network adapter is a versatile addition to your tech toolkit. Designed for users who need reliable Internet connections, it supports Ethernet 1000Base-T, 100Base-TX, and 10Base-T, making it compatible with a wide range of network configurations. With a data transfer rate of 1 Gbps, it's suitable for streaming, gaming, and transferring large files efficiently. Additionally, it features USB Power Delivery (up to 100 W), allowing you to charge your devices quickly. Its compact design, featuring a 13.1 cm integrated USB cable, makes it easy to carry and connect to your laptop or tablet, ensuring you have access to a stable network connection wherever you go.
  • Efficient connectivity
    The Belkin CONNECT network adapter offers seamless integration into any network setup with its Ethernet 1000Base-T, 100Base-TX, and 10Base-T capabilities, ensuring compatibility with a wide range of network speeds and configurations.
  • High-speed data transfer
    With a data transfer rate of 1 Gbps, this network adapter is designed to handle high-speed Internet connections, making it suitable for streaming, gaming, and large file transfers.
  • Versatile power delivery
    Features USB Power Delivery (up to 100 W), allowing you to charge your devices quickly while maintaining a stable network connection.
  • Compact and portable design
    The integrated 13.1 cm USB cable and compact form factor make it easy to carry and connect to your laptop or tablet, providing reliable network access wherever you go.
Belkin - network adapter - USB-C - Gigabit Ethernet x 1 + USB-C (power only) x 1
Network adapter
External
Interface (Bus) Type
USB-C
Ports
4.1 cm x 17.1 cm x 1.5 cm
29 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Power Delivery 3.0
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB Power Delivery (up to 100 watt)
Power Delivery 3.0
1 x 10/100/1000Base-T - RJ-45 - female , 1 x USB (power only) - 24 pin USB-C - female
1 x USB cable (integrated) - 13.1 cm
4.1 cm
17.1 cm
1.5 cm
29 g
Brand: Belkin
