The Belkin NetCam Wi-Fi Camera with Night Vision makes it easy to check in on your kids after school or watch your pet at play - right on your mobile device. The camera connects to your Wi-Fi router without the need of a computer.
The camera's wide-angle video captures large spaces, while its clear digital audio keeps you from missing conversations or noises. With night vision for recording in low light, NetCam is ideal for baby monitoring. It also lets you save video directly to your mobile device, so you can share your favorite memories.
Wide-angle video
Shows you more of the room so you know what's really going on. -
Easy mobile-device setup
Set up your camera from your iPhone, iPad, or Android device in minutes. No need for a computer. -
Night vision
Infrared lets you see clearly when there's little to no light. -
Email alerts
Enjoy peace of mind with movement-detection notifications. -
Mobile-device recording
Save live video to your smartphone or tablet. -
Digital audio
Listen to what's going on in the room.
- Belkin NetCam Wi-Fi Camera with Night Vision - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 640 x 480
- Optical Sensor Type
- CMOS - 1/4"
- Focal Length
- 3.1 mm
- Lens Iris
- F/2.6
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Resizing an image, image flip, image mirror
- Audio Support
- Wired, wireless
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG
- Max Digital Video Resolution
- 640 x 480
- Infrared LEDs
- Video Capture
- 640 x 480 @ 30 fps , 320 x 240 @ 30 fps , 160 x 120 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 3.1 mm
- Lens Iris
- F/2.6
- Horizontal Field of View (degree)
- 64
- Vertical Field of View (degree)
- 48
- Network Interface
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.96 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.76 |
