The ultra-light and protective Pocket Sleeve is the ideal accessory for your Microsoft Surface. Enough room to carry both your keyboard and tablet, it's also slim enough to easily stash in a backpack or handbag. Plus there's a built-in stylus holder as well as a storage pocket. So now everything you need to get the most out of your device can fit in one compact carryall.
Fits with & without keyboard
Now it's easy to take your Surface Pro and keyboard all in one slim and convenient case. -
Extra storage
Keep everything you need all in one place with an individualized stylus holder and accessories pocket. -
PROTECT & GO
Stylish and durable, the zip-up sleeve provides just the right fit to keep your Microsoft Surface Pro safe and secure. A soft inner lining also protects the screen and back from scratches while you're on the go. -
Easy access
Simply zip up the sleeve to keep your Microsoft Surface Pro 3 safe and secure when you're on the go. And then when you need your tablet, it's quick and easy to zip open and grab.
- Belkin Pocket - protective sleeve for tablet
- Product Type
- Protective sleeve for tablet
- Screen Size Compatibility
- 10"
- Material
- Neoprene
- Blacktop
- Designed For
- Microsoft Surface 3 (10.8 in)
- Material
- Neoprene
- Blacktop
Carrying Case
- Protective sleeve
- Recommended Use
- For tablet
- 10"
- Protection
- Scratch-resistant
- Closure Type
- Zipper
- Additional Compartments
- Stylus
- Stylus holder, soft inner lining
- Designed For
