Belkin N600 Dual Band Wireless Range Extender (Wall Mounted)
Quicklinx: 90R2WS00 Mfr#: F9K1122uk
  • IEEE 802.11n
The Belkin N600 Dual-Band Wi-Fi Range Extender expands your wireless network, while its compact, elegant design complements your home decoration. With high performance speeds of up to 300 Mbps (2.4 GHz) + 300 Mbps (5 GHz) and external antennas for superior range, you'll have strong, reliable Wi-Fi throughout your home. Simple Start makes set up quick and easy on any smartphone, tablet or laptop - just plug the Belkin N600 Dual-Band Wi-Fi Range Extender right into the wall, access simple start and you're ready to go in minutes. Crossband technology increase speeds vs. normal range extenders by switching to the least congested band. Compatible with G and N technology devices, the N600 Dual Band Wi-Fi Router makes home networking a lot easier by keeping all your Wi-Fi devices connected.
Belkin N600 Dual-Band Plug-In Wi-Fi Range Extender - Wi-Fi range extender - Wi-Fi
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Microsoft Windows XP SP3 or later, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 100Base-TX - RJ-45
90R2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
