Better Wi-Fi performance to browse the Web wirelessly
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you powerful signal strength and maximum coverage, while minimizing dead spots--so you can connect from virtually anywhere in your home.
Speed
The N300 provides wireless speeds of up to 300Mbps*--ideal for surfing, emailing and instant messaging.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're out of the box and onto the Web.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
+1 App
Enhance your online activities with Belkin's integrated SELF-HEALING app.
*The standard transmission rates--300Mbps, 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
MultiBeam technology
Belkin's exclusive MultiBeam antenna technology gives you powerful signal strength and maximum coverage, while minimizing dead spots - so you can connect from virtually anywhere in your home. -
Speed
The N300 provides wireless speeds of up to 300Mbps - ideal for surfing, emailing and instant messaging. -
Easy setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're out of the box and onto the web. -
Preset security
- Belkin F9K1002 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- Connection / user qty: 16
- TCP/IP, PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- NAT support, Stateful Packet Inspection (SPI), firmware upgradable, MIMO technology, Wi-Fi Protected Setup (WPS), reset button, MultiBeam technology
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Microsoft Certification
- Compatible with Windows 7
- System Requirements
- Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Apple MacOS X 10.5, Microsoft Windows Vista / 7
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Capacity
- Routing Protocol
- Static IP routing
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, ICES-003 Class B, RSS-210, FCC Part 15, RSS-139
- Status Indicators
- Status
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities, Self-Healing
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - 1 GHz - RAM 512 MB - HD 600 MB , MacOS X 10.5 - 1 GHz - RAM 512 MB - HD 600 MB
- Limited warranty - 2 years
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.76 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
