This streamlined digital multiport AV adapter makes it easy to connect a laptop or other device to your HDMI projector or monitor. One end of the adapter features four popular output connectors - Mini DisplayPort, USB-C, HDMI and VGA for broad compatibility across many devices. The other end of the adapter features an HDMI connector to input content to your projector or display.
Single cable solution
This multiport digital AV adapter eliminates the need for multiple single-point adapters that cause clutter and are easily misplaced. This neat solution remains connected to the projector/display to eliminate lengthy set-up times or the need for outside help from the IT team. Magnetized cable heads ensure AV installations in meeting rooms, auditoriums, classrooms or exhibition centers stay organized and functional. -
Security for your network
Clean, plug-and-play operation functions without additional software downloads, providing added security for all connected devices. -
Ultra HD 4K Video and Audio icon
This digital AV adapter supports video resolutions up to Ultra HD 4K and is backwards compatible for lower resolutions for an enhanced video experience. It also supports audio for all audio-enabled inputs - Mini DisplayPort, USB-C and HDMI (VGA does not support audio). -
USB-A power cable
The advanced circuitry within the digital AV adapter ensures high-quality performance across all inputs. It is powered by an attached USB-A cable which connects conveniently to your HDMI projector/monitor or a nearby power source for a seamless experience.
- Belkin Multiport to HDMI Digital AV Adapter - video / audio cable - Mini DisplayPort / HDMI / USB / VGA - 2.4 m
- Cable
- Video / audio cable - Mini DisplayPort / HDMI / USB / VGA
- Length
- 2.4 m
- Connectors
- HD-15 (VGA) - male (input) , Mini DisplayPort - male (input) , HDMI - male (input) , 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - male (output) , USB (power only) - male
- 4K support
- Cable Type
- Video / audio cable 4K support
- Interface Supported
- Length
- 2.4 m
- Recommended Use
- Projector, monitor
- Magnetised connectors
- Connectors
- 15 pin HD D-Sub (HD-15) - male (input) , Mini DisplayPort - male (input) , 19 pin HDMI Type A - male (input) , 24 pin USB-C - male (input)
- 19 pin HDMI Type A - male (output) , 4 pin USB Type A (power only) - male
