This MIXIT power pack lets you keep your devices charged no matter where you are, just plug in your device for immediate automatic charging. 2 USB ports mean you can simultaneously charge 2 smartphones, and high total power ensures optimal charging for tablets. Charge your battery pack before you leave the house, and take the power to charge smartphones, tablets or any USB-enabled device wherever you go.
Smart power
Enable auto charging simply by plugging your device in to this MIXIT power pack. Fully charged on arrival, it automatically detects your device and gets straight to work on powering it up. Recharging the power pack itself is also easy. -
Great at multi-tasking
The MIXIT power pack ensures that you'll always have an extra charge within reach. And it has two USB ports, which means you can charge a second device, such as a friend's smartphone, at the same time that you charge yours. With its compact and lightweight design, it's ideal for travel and easily slips into any handbag or backpack. -
A power fortress
A huge battery capacity means a huge amount of power that can be stored for a long time. Charge your tablet at optimum speed and power output, or recharge your smartphone a few times without refueling the power pack.
- Belkin MIXIT Metallic Power Pack 6000 power bank - USB
- Product Type
- Power bank
- 5 cm x 2.5 cm x 8.3 cm
- 132 g
- Grey
- Output Connector Type
- Total 2: USB - on cable: Micro-USB
- Max Electric Current
- 3.4 A
- Battery
- 6000 mAh
- Cables
- Micro-USB to USB cable - 15.2 cm
- 3-year warranty
- Product Type
- Power bank
- Designed For
- Camera, tablet, mobile phone
- 5 cm
- 2.5 cm
- 8.3 cm
- 132 g
- Enclosure Colour
- Grey
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 3.4 A
- LED indicator
- Capacity
- 6000 mAh
- Cables Included
- Limited warranty - parts and labour - 3 years
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
