Charge and sync your iPad, iPhone and iPod using just one cable. Simply plug the USB end directly into any USB port. Use the raised bump on 30-pin connector end to correctly orient the cable into your device, every time.
- Belkin MIXIT ChargeSync Cable - charging / data cable - 2 m
- Cable
- Charging / data cable
- Length
- 2 m
- Purple
- Connector
- USB - male
- Connector (Second End)
- Apple Dock - male
- Cable Type
- Length
- 2 m
- Purple
- Connector
- 4 pin USB Type A - male
- Apple Dock connector - male
