Belkin MIXIT™ DuraTek™ Micro-USB to USB Cable
Quicklinx: D2WHWS00 Mfr#: F2CU051bt04-BLK
Not just any charge cable, DuraTek was forged from superior quality materials for ultimate durability. Kevlar fibers reinforce the inner wiring for added strength, abrasion-resistant nylon forms a tough outer jacket, and highly flexible insulation minimizes damage from friction. The strength created by these resilient ingredients is further enhanced by smart design details to reinforce the cable at its stress points. This ensures the finished product can withstand demanding routines, and perform above and beyond expectation to deliver a cable that borders on indestructible.
  • Built with Dupont Kevlar
    One of the key ingredients of DuraTek's secret strength is Kevlar. This super-strong fiber is used the world over for everything from bulletproof vests and crash helmets to surfboards and extreme sports gear. Strong Kevlar strands are built into the cable adding ultimate strength. Able to flex without stretching, these fibers provide structure to keep the wires inside from damage.
  • Double braiding callout
    The external cable jacket is made from a premium and hard-wearing nylon. Double braiding is a technique used in rope making and gives maximum strength and added resilience.
  • Flexible insulation
    Inside the cable, many wires co-exist to provide better functionality and connectivity. Insulation protects the wires from damage as the cable bends and flexes, but some can cause stiffness, affecting the overall suppleness of the cable. The highly flexible insulation within DuraTek minimizes friction, allowing the cable to bend easily and the wires within to move without damage.
  • Better strain relief
    The strain relief - where the cable joins the connector head - is longer than that found on other cables. Made from flexible TPE, this added length and flexibility helps to absorb stress and reinforce the juncture between the cable and the connector head to prevent separation.
Belkin MIXIT DuraTek - USB cable - Micro-USB Type B to USB - 1.22 m
USB cable
Shielded
Drain wire, sync and charge, braided, EMI protection, abrasion-resistant, connectors with aluminium housing
Length
1.22 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
Rated Current
2.4 A
USB / USB 2.0
5-year warranty
USB cable
Shielded
Shielding Material
Mylar
Jacket Material
Thermoplastic elastomer (TPE)
Rated Current
2.4 A
Length
1.22 m
Connector
USB / USB 2.0
5-year warranty
