Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPod touch (5th generation) iPad with Retina Display (4th generation), or iPad mini at the fastest possible speed. The smaller, more durable Lightning connector is also reversible, which makes plugging it in easier than ever.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
- Belkin MIXIT Lightning to USB ChargeSync - Lightning cable - Lightning / USB - 1.2 m
- Cable
- Length
- 1.2 m
- Red
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Length
- 1.2 m
- Sync and charge
- Red
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
