Charge and Sync at the Speed of Lightning
Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPod touch (5th generation) iPad with Retina Display (4th generation), or iPad mini at the fastest possible speed. The smaller, more durable Lightning connector is also reversible, which makes plugging it in easier than ever.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
The MIXIT Collection
Mix it up with chargers, cables, audio, and power accessories that come in a full line of high-tech hues.
Made for iPod/iPhone/iPad certification
"Made for iPod," "Made for iPhone," and "Made for iPad" mean that an electronic accessory has been designed to connect specifically to iPod, iPhone, or iPad, respectively, and has been certified by the developer to meet Apple performance standards. -
Mix & match
The MIXIT Collection not only includes cables, chargers, audio and power accessories, so you can mix and match with other MIXIT products to create your favorite color combinations. -
Compact & portable
The longer 4-foot MIXIT Lightning to USB Cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road. -
Case compatibility
Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
- Belkin ChargeSync Cable - Lightning cable - Lightning / USB - 1.2 m
- Cable
- Length
- 1.2 m
- Purple
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- 1-year warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Length
- 1.2 m
- Sync and charge
- Purple
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- Limited warranty - 1 year
