Belkin Mini DisplayPort to HDMI Cable 4K - 1.8m
Quicklinx: FCYRWS00 Mfr#: F2CD080bt06
The Mini DisplayPort to HDTV display cable lets you stream high-quality A/V content from your laptop or tablet to your HDTV. Use it to watch movies, share photos, or expand your workstation with a mirrored desktop.
  • Durable 6-foot cable
    The cable's molded strain-relief design reduces strain on the cable to help prevent wear and tear. Its 6-foot length is ideal for connecting to hard-to-reach HDMI inputs on your HDTV.
  • Plug-and-Play wherever you go
    Seamless Plug-and-Play capability makes this cable ideal for quick media sharing in any setting. The cable has the design that helps you easily identify the "right side up" insertion point.
Belkin adapter cable - DisplayPort / HDMI - 1.8 m
Cable
Adapter cable - DisplayPort / HDMI
Length
1.8 m
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - male
Moulded, strain relief
Cable Type
Adapter cable
Interface Supported
DisplayPort / HDMI
Length
1.8 m
Connector
19 pin HDMI Type A - male
