Belkin Mini Displayport - HDMI Adapter 4K Compatible
Quicklinx: DDJPWS00 Mfr#: F2CD079BT
The Mini DisplayPort to HDTV Adapter lets you stream high-quality A/V content from your laptop or tablet to your HDTV. Use it in conjunction with an HDMI cable to watch movies, share photos, or expand your workstation with a mirrored desktop. The adapter offers molded-strain relief for flexibility at the connection points, reducing wear and tear from frequent use. A white label helps you identify which end is up for easy, quick insertion. The adapter is a pocket-sized, portable accessory for HDTV setups both at home and in the office. When used with an HDMI cable, the adapter offers plug-and-play capability that is ideal for presentations on the go.
  • Connect your laptop or tablet to your HDTV
  • Durable design resists wear and tear
  • Plug and play wherever you go
Belkin Mini DisplayPort to HDMI Adapter, 4k - adapter - DisplayPort / HDMI - 12.7 cm
Cable
Adapter - DisplayPort / HDMI
Length
12.7 cm
Connector
Mini DisplayPort - male (input)
Connector (Second End)
HDMI - female (output)
4K support
Cable Type
Adapter 4K support
Interface Supported
DisplayPort / HDMI
Length
12.7 cm
Moulded, strain relief
Connector
19 pin HDMI Type A - female (output)
