Just place your iPhone 12 series device against the MagSafe car mount and go. Designed to provide a seamless set-and-drive experience, while keeping your new iPhone safely mounted and conveniently within view in landscape or portrait mode.
Safe, powerful, magnetic
Belkin has designed our MagSafe Car Mount with a powerful magnetic module that keeps your iPhone 12 or iPhone 12 Pro safely mounted through all the road's bumps and turns. A high-quality base and sturdy vent clip ensure that your MagSafe Car Vent Mount stays safely in place. -
Rotate to view in portrait or landscape
The MagSafe Car Vent Mount rotates using a high-quality ball joint, so it's easy to flip from portrait to orientation with one hand. Set your playlist in portrait and flip to landscape to use your navigation app. -
Seamless, single-handed mount
Get in and go without stopping to mount your iPhone 12 or iPhone 12 Pro. The MagSafe mount lets you set your iPhone in place without slowing you down. -
Cable management for easy charging
Keep your playlist, calls, and navigation going without interruption. The thoughtful design includes convenient cable management, so a charge is always within reach.
- Belkin MagSafe PRO - car holder for mobile phone
- Product Type
- Car holder
- Intended For
- Mobile phone
- Suitable For Installation
- Car
- 2-year warranty
- Designed For
- Apple iPhone 12, 12 mini, 12 Pro, 12 Pro Max
- Product Type
- Car holder
- Intended For
- Mobile phone
- Car
- Placing / Mounting
- Car ventilation grid
- Return - 90 days
- Designed For
