Belkin iPhone 5 and 6 Desktop Charge and Sync Desktop Dock - Gold
Quicklinx: BB3MWS00 Mfr#: F8J045BTGLD
Charge and sync your iPhone 5 with the compact and stylish Belkin Charge + Sync Dock. To use, plug the 4-foot hardwire USB cable into your laptop and dock your device. To charge from the wall, simply plug it into your existing power supply, then plug into any wall outlet.
  • Charge and sync at the speed of lightning
  • Built-in lightning connector
    The Belkin Charge + Sync Dock has a built-in lightning connector, so you can dock your iPhone 5 to charge and sync, hands-free. If your speakers, lightning connector and AUX port are fully exposed when your case is on, you should be able to easily dock your iPhone without removing the case. For best results, remove your case before you dock.
Belkin MIXIT ChargeSync Dock - docking station
Docking station
Intended For
Mobile phone, digital player
Gold
Apple iPhone 5, 5s
Docking station
Intended For
Gold
IPhone / IPod docking - Apple Dock connector / Lightning
Synchronization function
Apple iPhone 5, 5s
