With Belkin ScreenForce, it's easy to keep your screen as pristine and protected as the day you got it. Engineered to be stronger than regular glass, TemperedGlass provides resilient, hard-wearing protection for your screen. Manufactured using premium glass, it retains the smooth glide and feel of the screen, and is tested extensively to deliver the brightness, sharpness and clarity you expect from your tablet.
Tested for scratch and impact protection
Engineered from premium tempered glass, your screen will always have superior impact protection and enhanced resistance from scratches and scuffs. -
Visible clarity
Designed and engineered from high-quality, durable glass to deliver the brightness, sharpness and detail you expect from your screen. The result is a crystal-clear protective layer that provides the same visual experience as the original screen. -
Feels like your natural screen
Glass composition means your finger glides smoothly over the screen protector, just like it does over your device screen. The super-thin glass preserves touchscreen sensitivity to respond accurately to your touch. What's more, the advanced anti-fingerprint layer is engineered to help keep your screen feeling clean and looking clear.
- Belkin ScreenForce - screen protector for tablet
- Product Type
- Screen protector - glass
- Intended For
- Tablet
- Screen Size Compatibility
- 11"
- Protection
- Scratch-resistant, impact protection, fingerprint-proof
- Package Content
- Cleaning cloth, screen protector, dust removal sticker
- Product Material
- Tempered glass (9H)
- Thickness
- 0.33 mm
- Limited lifetime warranty
- Designed For
- Apple 11-inch iPad Pro (1st generation)
- Product Type
- Intended For
- Tablet
- 11"
- Protection
- Package Content
- Product Material
- Thickness
- 0.33 mm
- Designed For
