Belkin iPad 9.7" Tempered Glass
Quicklinx: FCZ6WS00 Mfr#: F8W933zz
With SCREENFORCE TemperedGlass for iPad, it's easy to keep your screen as pristine and protected as the day you got it. Engineered to be stronger than regular glass, TemperedGlass provides resilient, hard-wearing protection for your iPad screen. Manufactured using premium Japanese glass, it retains the smooth glide and feel of the screen, and is tested extensively to deliver the brightness, sharpness and clarity you expect from your iPad. It's compatible with Apple Pencil making it easy to jot down notes or design seamlessly. The Easy Align tray enables simple and precise application, to provide maximum protection.
  • Tested for scratch and impact protection
    Engineered from premium Japanese tempered glass, your iPad screen will always have superior impact protection and enhanced resistance from scratches and scuffs. Proven in testing to have a hardness rating of 9H, it's the highest level of scratch protection available.
  • Compatible with Apple pencil and Apple cases
    With this highly responsive and perfectly precise screen protector, you can enjoy the freedom of using your Apple pencil to seamlessly paint, draw, or take notes in a such a smooth and flawless manner, you won't even know it's there. And screen protectors are also conveniently compatible with most Apple cases for all-around protection.
  • Visible clarity
    Designed and engineered from high quality, durable Japanese glass to deliver the brightness, sharpness and detail you expect from your iPad screen. The result is a crystal-clear protective layer that provides the same visual experience as the original screen.
  • Feels like your natural screen
    Glass composition means your finger glides smoothly over the screen protector, just like it does over your device screen. The super-thin 0.29mm glass preserves touchscreen sensitivity to respond accurately to your touch. What's more, the advanced anti-fingerprint layer is engineered to help keep your screen feeling clean and looking clear.
  • Easy, precise application
    A precisely applied screen protector provides greater protection for your iPad. For a simple and bubble-free application, just use the included Easy Align Tray to help seamlessly align your protector to your iPad screen.
Belkin ScreenForce - screen protector for tablet
Screen protector - glass
Intended For
Tablet
Protection
Scratch-resistant, impact protection, fingerprint-proof
Package Content
Cleaning cloth, screen protector, dust removal sticker, EZ-align tray
Product Material
Tempered glass (9H)
Thickness
0.29 mm
Apple 9.7-inch iPad (5th generation, 6th generation)
Intended For
Tablet
Protection
Package Content
Product Material
Tempered glass (9H)
Thickness
0.29 mm
