Belkin High Speed HDMI Cable with Ethernet - 1m
Quicklinx: DNT9WS00 Mfr#: F3Y021BT1M
Length: 1m
£4.83 ex VAT
£5.79 inc VAT
Connect your Blu-ray player, gaming console or other HD device to an HDTV. The Belkin HDMI Cable with Ethernet is perfect for connecting Wi-Fi enabled devices to your Internet-enabled HDTV to stream movies, listen to music and view content.
  • Get the most out of your HDTV
    Unleash the world of full 1080p HD cinema-quality movies at home. With bandwidth speeds of up to 10.2 Gbps, the Belkin HDMI Cable with Ethernet is designed for home theater enthusiasts who demand the most from their HDTV and high-end AV equipment. The cable also features a built-in audio return channel for smooth sound and a refresh rate of up to 120 Hz for a clear picture that reduces blurring during fast-action scenes. In addition, you can enjoy all your 3D movies just as you would in the theater with 3D-compatibility.
  • Belkin quality assurance
    24K gold-plated connectors minimize signal loss, while 2-layer shielding restricts outside interference. The Belkin High-Speed HDMI Cable surpasses industry standards to deliver exceptional picture and sound. AV Cables from Belkin are constructed to achieve peak performance to give you the best viewing experience possible.
Belkin High Speed HDMI Cable with Ethernet - HDMI cable with Ethernet - 1 m
Cable
Cable Length
1 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support
Cable Type
HDMI cable with Ethernet 4K support
Cable Length
1 m
Plated Connector
Gold
HDMI Ethernet Channel (HEC), Pure Copper conductors
Connector
19 pin HDMI Type A - male
Limited warranty - lifetime
Length: 1m
Brand: Belkin
