Your basket is empty
Belkin High Performance Cat 6 UTP Patch Cable 10M
Customer rating: 5.0* (Write a review)
Quicklinx: 3B3NWS00 Mfr#: A3L980B10M-BLUS
Length: 10m
Colour: Blue
£8.41 ex VAT
£10.09 inc VAT
Express delivery Delivered on Tuesday
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Belkin High Performance patch cable - 10 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Molded, snagless
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568A
Plated Connector
Gold
Molded, snagless
Length
10 m
Blue
Connector
RJ-45 - male
RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
Customer reviews
Write a review for the Belkin High Performance Cat 6 UTP Patch Cable 10M here!
Excellent
Reviewed by Sina Mohajer. Review Posted 15/02/2006
Excellent cable, high quality plastic used to insulate the case, and the heads are durable, with easy bendable ends to ensure no strain on cable when fitted in tight places.
I havent used CAT5 on a gigabit network so I cant tell you on any speed differences compared to this CAT6.
Highly Recommended.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Length: 10m
Colour: Blue
Brand: Belkin
Price Range Ex VAT: 0 - 50
