The Belkin High Speed Modem Cable is guaranteed to give you the fastest Internet access possible with data transmission speeds of up to 100Mbps. The Belkin High Speed Modem Cable features Signal Exact Twist technology, Category 5 cable construction and 24K Gold Plated contacts, which allows your modem to achieve maximum performance. When compared to regular phone cables, the Belkin Internet Modem Cable delivers a signal 10 times faster and stronger than the standard cable.
- Belkin High Speed Internet Modem Cable phone cable - 4.6 m
- Phone cable - CAT 5
- Molded, snagless
- Length
- 4.6 m
- Localisation
- United Kingdom
- Connector
- RJ-11 - male
- Connector (Second End)
- BT - male
- Limited lifetime warranty
- Network Cable Type
- Jacket Material
- PVC
- Plated Connector
- Gold
- Molded, snagless
- Length
- 4.6 m
- Localisation
- United Kingdom
- Connector
- RJ-11 - male
- BT - male
