Designed using thinnest material that hugs the curves of your device, FreeStyle iPad Air cover is the perfect example of the old adage, "Less is More". With the same durable construction and thoughtful design details found in all iPad Air covers, the FreeStyle case for iPad takes sleek protection to a whole level.
The FreeStyle cover iPad Air case comes with an innovative QuickStand, a front cover that snaps to the back of the case. When opened, you can use it as a stand, and rotate your iPad Air to view content in either portrait or landscape mode. When you want to use the slim case on its own, just detach it and go.
More views, more you
Designed using thinnest material that hugs the curves of your device, FreeStyle iPad Air cover is the perfect example of the old adage, "Less is More". With the same durable construction and thoughtful design details found in all iPad Air covers, the FreeStyle case for iPad takes sleek protection to a whole level. -
Protection & viewing versatility
The FreeStyle cover iPad Air case comes with an innovative QuickStand, a front cover that snaps to the back of the case. When opened, you can use it as a stand, and rotate your iPad Air to view content in either portrait or landscape mode. When you want to use the slim case on its own, just detach it and go. -
Secure fit
FreeStyle iPad Air cover isn't just about good looks-it also provides reliable protection. Snap your iPad Air into the fitted frame to securely hold it in place and just push down on the corners of the frame when you want to remove it. -
Nothing blocks your view
The overall construction and frame design of the FreeStyle cover iPad Air case is incredibly minimalist, giving you maximum protection without adding bulk. The form-fitting frame is so unnoticeable; it virtually disappears once your iPad Air is in place. -
Quality craftsmanship & materials
The Belkin FreeStyle cover case for iPad Air is made of durable, device-hugging material that's super soft to the touch. It stretches to the shape of your iPad Air for an incredibly tailored, barely there fit. A velvety inner lining keeps your screen safe and cushioned. -
Choose your viewing angle
Use the FreeStyle iPad Air cover to position your iPad Air at the angle that suits you best. The inner lining is set with grooves at various positions so you can slide your tablet closer to you or angle it further away-whatever's most comfortable for you. -
Folds into the perfect angle for typing
The FreeStyle iPad Air cover case also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen. -
Clasp keeps everything in place
The FreeStyle cover for iPad Air features a secure clasp that snaps shut to keep the front cover closed when you're on the go. The same clasp can be used to hold the cover back and out of the way while you're using your tablet.
- Belkin FreeStyle - protective cover for tablet
- Product Type
- Protective cover for tablet
- Blacktop
- Blacktop
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Closure Type
- Clasp closure
- Adjustable viewing angles, soft inner lining
- Cover Features
- Stand function
