Belkin Flexible USB Cable Adapter
Quicklinx: 85NDWS00 Mfr#: F3U134CPFLEX
Connect USB devices easily in tight workspaces. The Flexible USB Cable Adapter from Belkin lets you connect USB devices to your notebook or desktop computer in even the most cramped workspaces. This small, lightweight USB adapter has a flexible swivel connector that bends and rotates 180 degrees, so you can conveniently connect USB devices to adjacent ports. Its compact size and advanced functionality make it the ideal accessory to include inside your laptop case - a great solution for today's mobile professional.
  • Flexible design
    The 180° rotation feature of the Belkin Flexible USB Cable Adapter ensures it can fit into tight spaces, making it perfect for cluttered workstations or behind furniture.
  • Universal compatibility
    Designed to connect with any PC, this USB adapter enhances your setup by providing an easy connection for all your USB Type-A devices.
Belkin Flexible USB Cable Adapter - USB adapter - USB to USB
USB adapter
180° rotation
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB adapter
180° rotation
Connector
