Belkin Flat 2.4amp Lightning Sync charge cable for Apple items - Black
Quicklinx: B9ZZWS00 Mfr#: F8J148bt04-BLK
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
  • Flexible charging at the speed of lightning
    Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPad mini, iPad Air, iPad or iPod Touch at fast speeds. Its flat, ultra-flexible design makes it easy to stash without getting tangled. Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere.
  • Compact and portable
    The longer 4-foot MIXIT Lightning to USB cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Case compatibility
    Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
Belkin MIXIT Flat Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.22 m
Cable
Length
1.22 m
Connector
Lightning - male
Connector (Second End)
USB - male
Flat
Cable Type
Lightning cable flat
Interface Supported
Lightning / USB 2.0
Length
1.22 m
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
