Belkin Family Car Charger with Extension Hub 4 Port 7.2A/36W - Black
Quicklinx: BB5TWS00 Mfr#: F8M935bt06-BLK
Type: Charger
£27.63 ex VAT
£33.15 inc VAT
Charging is no longer limited to the front seat with the Road Rockstar. Designed with a 6ft cable, and 4 USB ports, you can seamlessly charge 4 devices simultaneously while on the go. 2 front seat USB ports charge smartphones at optimum speeds with shared 2.4A, while the extendable hub allows backseat passengers to charge 2 tablets simultaneously at 2.4A per port, perfect for watching movies on long road trips.
  • Charge at optimal speeds
    Provides optimal power to each port allowing for fast charging for smartphones (1A) and tablets (2.4A).
  • Charge 4 devices at once
    2 USB ports for driver and passenger, while 2 USB ports extend to the backseat passengers.
  • Extend USB ports to the back
    The 6ft cable allows for backseat passengers to easily access the charger.
  • Compatible with most cars
    Plugs into cars CLA and then clips to driver/passenger backseat pocket for easy accessibility to charging ports.
Belkin Road Rockstar car power adapter
Car power adapter
Output Connector Type
USB
Cables
- 1.8 m
Car power adapter
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Output connectors
Total 4: 4 pin USB Type A
Power Provided
36 Watt
Max Electric Current
7.2 A
Built-in 2-port USB hub
- 1.8 m
Type: Charger
Brand: Belkin
Price Range Ex VAT: 0 - 50
