Belkin Ethernet + Power Adapter with Lightning Connector
Quicklinx: F665WS00 Mfr#: B2B165BT
RELIABLE INTERNET AND POWER, EVERY TIME
This Ethernet + Power Adapter with Lightning Connector is the perfect solution when Wi-Fi connectivity is inconsistent, overextended, or non-existent. With Ethernet and Lightning ports, you can connect to a secure network while continuing to charge your device. Power over Ethernet (PoE) compatibility provides another convenient way to connect and charge simultaneously with a single cable. Combining Ethernet and reliable power makes this adapter perfect for businesses using cloud-based POS systems.
Made for: Businesses and professionals who need reliable Ethernet and power for their portable devices
Compatible with iOS 10.3.3 or later. The Belkin Connect app keeps your firmware up to date for optimal functionality.
ETHERNET + CHARGE DUAL FUNCTIONALITY
No more choosing between power and reliable internet connection. This adapter allows pass-through charging to power the device while Ethernet connection provides a reliable internet connection at the same time.
SUPPORTS POWER OVER ETHERNET
This adapter works with your existing Power over Ethernet (PoE) enabled internet connection. When PoE is available, there’s no need to plug in a Lightning cable, simply charge through your existing PoE enabled cable.
FAST, RELIABLE AND SECURE CONNECTION
A hard-wired Ethernet connection provides reliable speeds up to 480 Mbps. Having a connection you can count on makes this a must-have for POS systems.
12W KEEP YOU CHARGED
Power user approved, you can run even the most power-draining apps with confidence. Pass-through power up to 12W will keep connected devices charged without compromising connectivity.
MADE FOR IPAD CERTIFICATION
MFi-certified ('Made for iPad') means that an electronic accessory has been designed to connect specifically to iPad and has been certified by the developer to meet Apple performance standards.
2-YEAR LIMITED WARRANTY
The Ethernet + Power Adapter with Lightning Connector is protected by a Belkin 2-Year Limited Warranty. Belkin International, Inc. ("Belkin") warrants to the original purchaser of this Belkin product that the product shall be free of defects in design, assembly, material, or workmanship up to 2-years.
  • Streamlined connectivity to Ethernet and power at the same time
  • 480 Mbps for fast, reliable Ethernet connection
  • Supports up to 12W of power to keep devices fully charged
  • MFi certified for quality assurance
  • Supports power over Ethernet (PoE) at up to 12W
  • Ethernet + charge dual functionality
    No more choosing between power and reliable Internet connection. This adapter allows pass-through charging to power the device while Ethernet connection provides a reliable Internet connection at the same time.
  • Supports Power over Ethernet
    This adapter works with your existing Power over Ethernet (PoE) enabled Internet connection. When PoE is available, there's no need to plug in a Lightning cable, simply charge through your existing PoE enabled cable.
  • Fast, reliable and secure connection
    A hard-wired Ethernet connection provides reliable speeds up to 180 Mbps. Having a connection you can count on makes this a must-have for POS systems.
  • 12W power keeps you charged
Belkin Ethernet + Power Adapter with Lightning Connector - network adapter - Lightning - 10/100 Ethernet (PoE) x 1
Network adapter
External
Interface (Bus) Type
Lightning
Ports
5.38 cm x 2.15 cm x 14.4 cm
64 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
180 Mbps
Performance
Pass-through power: 12 W , Maximum electric current: 2.4 A , PoE power budget: 10 W
White
Apple 10.5-inch iPad Pro; 12.9-inch iPad Pro (3rd generation); 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2
Network adapter
External
Lightning
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
180 Mbps
Performance
PoE
1 x 100Base-TX (PoE) - RJ-45 - female , 1 x Apple Lightning (power only) - female
1 x Lightning cable (integrated)
MFI, Plug and Play
White
5.38 cm
2.15 cm
14.4 cm
64 g
-40 °C
85 °C
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2
