Belkin Dual USB Car Charger  2 x 2.4Amp - Black
Quicklinx: D7GMWS00 Mfr#: F8M930BTBLK
Keep all your devices powered up while on the road with the Belkin BOOST?UP 2-Port Car Charger. This sleek car charger allows you to simultaneously charge up to two devices, making it a great choice for keeping your whole family's devices powered up and ready while on the go.
Thanks to its two USB-A charging ports, the Belkin BOOST?UP 2-Port Car Charger ensures you never have to prioritize which mobile device needs charging the most. Great for giving your phone a little extra juice on the way to work or for keeping children's entertainment devices powered up during long road trips, the BOOST?UP 2-Port Car Charger has a sleek design that fits seamlessly in your car's charging port to keep the entire family connected.
The charger's USB ports are universal, allowing you to pair it with any USB-A cable. As long as you have the corresponding cable, you can use the charger with smartphones, tablets, cameras, portable battery packs, Bluetooth speakers, smartwatches, and more. The built-in LED light lets you know when your devices are charging.
  • Quickly charge two smartphones on the road
  • Charge multiple devices simultaneously
  • Universally compatible to work with any USB-A cable
  • Power up quickly
    This car charger offers combined power of 24 watts (4.8 amps) with each port having a dedicated 2.4 amps. This allows you to charge your smartphones and tablets quickly and safely.
Belkin BOOST UP Car Charger car power adapter - USB - 24 Watt
Car power adapter
Output Connector Type
Total 2: USB
Max Electric Current
4.8 A
Power Provided
24 Watt
Power Device Details
2 x - 4 pin USB Type A - 2.4 A
Car power adapter
Tablet, mobile phone
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Output connectors
Total 2: 4 pin USB Type A
Power Provided
24 Watt
4.8 A
2 x 4 pin USB Type A - 2.4 A
LED indicator
Equipment Protection Value
2500 US Dollars
