Belkin Daisy-Chain Cable for Pro3 Dual User 1m
Quicklinx: C0FSWS00 Mfr#: F1D109-03
OmniView PRO Series Daisy-Chain Cables allow you to daisy-chain multiple PRO3, PRO2, SMB CAT5, and SE Plus KVM Switches to expand your server configuration. The advanced wiring design and coaxial VGA cabling preserve signal integrity from the first to the last server.
Belkin OmniView Dual PRO Daisy-Chain Cable - stacking cable - 91 cm - grey
Stacking cable
Molded
Length
91 cm
Connector
36 PIN mini-Centronics - male
Connector (Second End)
Grey
OmniView Dual-User PRO3
Network Cable Type
Stacking cable
Jacket Material
PVC
Molded
Length
91 cm
Grey
Connector
Belkin OmniView Dual-User PRO3
