The Belkin CoolSpot Cushion Laptop Cooling Pad keeps your laptop - and your lap - cool and comfortable, whether you're gaming, browsing, sharing or shopping. It minimizes heat to help your legs stay comfortable and your laptop running at its best.
The ergonomic design has a padded base that's comfortable to rest on your lap. The angled top positions your laptop perfectly for typing, while a no-slip ledge holds your laptop in place. The Belkin CoolSpot Cushion seamlessly integrates with any laptop to create a stable surface anywhere you want.
keeps your legs cool & your laptop happy
The Belkin CoolSpot Cushion Laptop Cooling Pad keeps your laptop - and your lap - cool and comfortable, whether you're gaming, browsing, sharing or shopping. It minimizes heat to help your legs stay comfortable and your laptop running at its best. -
enjoy the comfort of a padded lap desk
The ergonomic design has a padded base that's comfortable to rest on your lap. The angled top positions your laptop perfectly for typing, while a no-slip ledge holds your laptop in place. The Belkin CoolSpot Cushion seamlessly integrates with any laptop to create a stable surface anywhere you want. -
whisper-like efficiency
The curved shape of the patented AirFlow Wave design creates a continuous, evenly dispersed stream of air flowing under your laptop. This design makes for a quieter fan that won't distract from your music, movies and games. -
works well on soft surfaces
Most laptop cooling pads pull in air from a single bottom vent, which can get blocked when placed on a soft surface like a couch or comforter. The Belkin CoolSpot Cushion's dual intake vents continuously pull in cool air from both the back and the bottom, giving you the freedom to use your laptop on soft surfaces. -
powered by your laptop usb port
The Belkin CoolSpot Cushion is USB-powered, so there's no need to carry around extra cords or a bulky battery pack - just plug it into your laptop and start cooling.
