Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Belkin Connect USB-C to 4-Port USB-C Hub
Quicklinx: J79ZWS00 Mfr#: AVC018btBK
16 In Stock
£24.91 ex VAT
£29.89 inc VAT
Connect all your USB-C devices with a sleek, compact, Plug-and-Play solution and transfer your data 2x faster.
  • Connect and create with 4 USB-C ports
    Connect USB-C peripherals - including cameras or webcams, keyboards, mice, audio interfaces, and external SSD PCIE hard drives - quickly and painlessly. Whether you're in the office creating content, at home gaming, or setting up a workstation for remote use, this 4-port hub will keep you up to speed. With a max of 10 Gbps high speed data transfer, it won't flinch when you're editing videos or trying to level up in-game. Compatible with MacBook, iPad, Chromebook, or PC, when you need to expand, this hub is at your command.
  • Achieve up to 10 Gbps transfer speeds
    Build a powerful workstation for seamless streaming and gaming, and lightning-fast downloads and uploads.
  • Universal compatibility
    Connect your older USB-C enabled devices with backwards compatibility.
  • No drivers needed
    A Plug-and-Play solution with 4 ports to connect your USB-C peripherals.
Belkin - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB-C
Performance
Data transfer rate: 10 Gbps
USB Power Delivery (up to 100 watt), FRS, audio over USB-C, backwards compatibility, USB powered, Post-consumer Recycled Plastic
7.62 cm x 4.32 cm
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB-C
Performance
3 x USB 3.2 Gen 2 Type C , 1 x USB 3.2 Gen 2 Type C pass-through
USB-C cable - 22 cm
Plug and Play, RoHS
7.62 cm
4.32 cm
Brand: Belkin
