This slim, portable USB-C adapter allows you to easily create a workstation anywhere and makes traveling between workspaces easy. With pass-through charging up to 100W, there's no need to choose between port expansion and power.
                Travel-ready compact designPerfect for remote and flex-work schedules, this USB-C hub adapter is small and simple enough to take anywhere and set up a mini workstation in moments. An aluminum finish matches popular devices and looks great when you're at home, office, or school.
                Connect in 4KExpand your screen space and get crystal-clear resolution when you get to work. Just connect your 4K monitor using the HDMI 1.4 port.
                Up to 100W power deliveryGo ahead and get in the zone. The USB-C port supports pass-through power up to 100W, so your laptop or mobile device is always getting a charge.
- Belkin CONNECT USB-C 7-in-1 Multiport Adapter - docking station - USB-C - HDMI
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI
- Product Type
- Docking station
Video
- Max Resolution Details
- 4K
- USB 3.0, Power Delivery 3.0, Battery Charging 1.2
- Expansion Slots
- 1 (total) / 1 (free) x microSD , 1 (total) / 1 (free) x SD Memory Card
- 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C , 2 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A
- Input Device
- SD card reader, microSD card reader
- Cables Included
- 1 x USB-C cable - integrated
- 100W power delivery
