Connect your laptop to a 4K monitor, projector, and other devices with the USB-C 4-in-1 Multiport Adapter. This compact adapter is the perfect solution for home, the office, or in-between workstations. It features two USB-A ports to charge and connect your smartphone, tablet, keyboard, thumb drive, mouse, or other high consumption device while its HDMI port connects your MacBook Pro, Chromebook, or other USB-C laptop to a display with up to 4K resolutions. Plug in a power adapter or charging cable for up to 100W of pass-through power so you don't have to choose between port expansion and charging. 5 Gbps of bandwidth delivers fast data transfer between computer and peripheral devices. Encased in a sleek aluminum finishing that matches popular devices, this adapter is a stylish addition for your work, study, or play setup.
- Belkin CONNECT 4-in-1 multiport hub adapter - USB-C - HDMI
- Product Type
- Multiport hub adapter
- Docking Interface
- USB-C
- Video Interfaces
- HDMI
- 9 cm x 4.5 cm x 1.3 cm
- Product Type
- 9 cm
- 4.5 cm
- 1.3 cm
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz
- 2 x USB 3.1 - 9 pin USB Type A , 1 x display / video - 19 pin HDMI Type A , 1 x USB-C - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - integrated
- 4K Ultra HD, 100W power delivery
