Belkin CONNECT USB-C 4-in-1 Multiport Adapter
Quicklinx: J79DWS00 Mfr#: AVC006btSGY
£43.26 ex VAT
£51.91 inc VAT
Connect your laptop to a 4K monitor, projector, and other devices with the USB-C 4-in-1 Multiport Adapter. This compact adapter is the perfect solution for home, the office, or in-between workstations. It features two USB-A ports to charge and connect your smartphone, tablet, keyboard, thumb drive, mouse, or other high consumption device while its HDMI port connects your MacBook Pro, Chromebook, or other USB-C laptop to a display with up to 4K resolutions. Plug in a power adapter or charging cable for up to 100W of pass-through power so you don't have to choose between port expansion and charging. 5 Gbps of bandwidth delivers fast data transfer between computer and peripheral devices. Encased in a sleek aluminum finishing that matches popular devices, this adapter is a stylish addition for your work, study, or play setup.
  • Compact solution
    The compact design of USB-C 4-in-1 Multiport Adapter allows you to create a mini workstation or travel between workspaces with ease. Its aluminum finish matches popular devices, giving you a sleek solution for your office, home, or on the go.
  • 4K HDMI port
    The 4-in-1 adapter easily connects your laptop to an HD monitor, projector, or other display with its HDMI 1.4 port, giving you resolutions up to 4K @ 30 Hz.
  • Connect + charge with 100W power delivery
    Keep your laptop powered up while connected to your peripherals. The 4-in-1 adapter supports pass-through charging, so you don't have to choose between port expansion and power.
Belkin CONNECT 4-in-1 multiport hub adapter - USB-C - HDMI
Multiport hub adapter
Docking Interface
USB-C
Video Interfaces
HDMI
9 cm x 4.5 cm x 1.3 cm
9 cm
4.5 cm
1.3 cm
Video
Max Resolution Details
3840 x 2160 - 30 Hz
2 x USB 3.1 - 9 pin USB Type A , 1 x display / video - 19 pin HDMI Type A , 1 x USB-C - 24 pin USB-C
1 x USB-C cable - integrated
4K Ultra HD, 100W power delivery
Brand: Belkin
