The Belkin CONNECT 11-in-1 Pro docking station is designed to meet diverse connectivity needs with its array of ports and features. With a robust USB-C cable extending up to 1 m, this docking station supports various devices allowing for seamless integration into any workspace. The support for up to 8K resolution and multiple displays ensures that users can achieve high-definition visuals for professional presentations or immersive gaming experiences.
Equipped with safety features such as overcurrent, overload, overvoltage, and short circuit protection, the Belkin CONNECT docking station offers peace of mind while ensuring reliable performance. Power delivery of up to 96 W makes it suitable for charging laptops and other devices, while supporting data transfer rates of up to 10 Gbps facilitates quick and efficient file transfers. It’s an ideal solution for anyone looking to enhance their workstation with comprehensive connectivity and advanced technology.
Robust connectivity options
The docking station offers a wide range of interfaces including HDMI, Ethernet, and audio ports, allowing easy connections to various devices and peripherals. -
Advanced power delivery
With a power output of 150 W, it can efficiently power multiple devices while providing 96 W USB-C Power Delivery for fast charging. -
High-performance data transfer
Equipped with capabilities for data transfer rates up to 10 Gbps, this docking station ensures efficient file sharing and communication between devices. -
Safety features included
The device is designed with multiple protection technologies, including overcurrent and short circuit protection, ensuring safe usage. -
Support for multiple displays
Allows dual and triple display configurations, enhancing productivity with more screen real estate for multitasking.
- Belkin CONNECT 11-in-1 Pro - docking station - USB-C - 2 x HDMI, USB-C - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 2 x HDMI, USB-C
- 5.425 cm x 9.1 cm x 13.2 cm
- 885 g
- Space grey
- Networking
- Gigabit Ethernet
- Power
- Power supply AC 100-240 V (50/60 Hz) 150 Watt Power Provided
- 2-year warranty
- Product Type
- Docking station
- 5.425 cm
- 9.1 cm
- 13.2 cm
- 885 g
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 8K - 30 Hz (DisplayPort 1.4 over USB-C) , 4K - 120 Hz (DisplayPort 1.4 over USB-C) , 4K - 60 Hz (Dual Display) , 4K - 60 Hz (Triple Display)
- Data Link Protocol
- Gigabit Ethernet
- Expansion Slots
- 1 (total) / 1 (free) x SD Memory Card ¦ 1 (total) / 1 (free) x microSD
- 1 x USB - 9 pin USB Type A , 2 x USB-C 3.2 - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone 3.5 mm , 1 x USB-C with Power Delivery 3.0 (96 W) - 24 pin USB-C , 1 x USB-C / DisplayPort - 24 pin USB-C , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x network - 1000Base-T - RJ-45
- Input Device
- SD card reader, microSD card reader
- Cables Included
- 1 x USB-C cable - external - 1 m
- Gallium Nitride (GaN) technology, triple display support, 96W power delivery, up to 10Gbps data transfer, fire-resistant housing, overcurrent protection, overload protection, overvoltage protection, short circuit protection, DisplayPort Alt Mode, power LED status
- RoHS, REACH, Plug and Play, USB Power Delivery 3.0
- Power Device
- Power supply
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 150 Watt
- OS Required
- Microsoft Windows, Apple MacOS, Google Chrome OS
- Limited warranty - 2 years
- 0 °C
- 40 °C
