Belkin CONNECT Universal DisplayLink Powered Triple Display Docking Station
Quicklinx: J79MWS00 Mfr#: INC007vfBK
13 In Stock
£248.75 ex VAT
£298.50 inc VAT
Display up to 4K video resolutions on up to three monitors with the universal USB-C triple display dock. Its DisplayLink technology easily connects your monitors to any computer, including MacBook, Chromebook, and Windows laptops. The docking station features multiple video ports - 2x DisplayPort and 3x HDMI - for convenient and flexible video connections. Access all the peripherals you'll need with 5x USB-A ports and a USB-C port, as well as Gigabit Ethernet, 35 mm audio in/out, and up to 85 W of USB-C PD power.
  • Compatible with MacBook, Chromebook and Windows
    DisplayLink technology makes it easy to connect any display to any computer, including MacBook, Chromebook, Windows, and more.
  • Triple 4K display
    Plug into one, two, or three extended displays in up to 4K resolutions at the same time with its flexible video ports, 3x HDMI and 2x DisplayPort.
  • Power Delivery up to 85 W
    The dock supports up to 85 W of USB-C Power Delivery to all your connected devices through a single cable.
  • DisplayLink technology
    DisplayLink graphics technology works across computing platforms and connector types, making nearly every monitor and system work together. Just plug in your MacBook, PC, or Chromebook and they can all use the same large displays, keyboard, and mouse. Whether you're working, streaming, or gaming, you'll enjoy simple connections, solid connectivity, and ultra-low latency.
Belkin CONNECT Universal USB-C Triple Display Dock - docking station - USB-C - 3 x HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
3 x HDMI, 2 x DP
Gigabit Ethernet
Power supply 150 Watt Power Provided
Docking station
Enclosure Colour
Video
Max Resolution Details
4K
1 x USB-C with Power Delivery (85 W) - 24 pin USB-C , 1 x USB-C 3.0 - 24 pin USB-C , 5 x USB-A 3.0 - 9 pin USB Type A , 3 x display / video - HDMI - 19 pin HDMI Type A , 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone 3.5 mm
1 x USB-C to USB-C cable - 1 m
85W power delivery, triple display support
DisplayLink certified, REACH, RoHS
Power supply
Power Provided
150 Watt
Microsoft Windows, Apple MacOS, Google Chrome OS
Brand: Belkin
