The Belkin Connect surge protector is an essential device for anyone looking to protect and power multiple devices simultaneously. With its integrated 2 m power cable and both USB-C and USB-A ports, it offers versatile connectivity options for a wide range of electronics. The surge protector's 900 Joules energy rating ensures your devices are shielded from voltage spikes, while the 'Protected' indicator light provides visual confirmation of your devices' safety. Additionally, its wall-mountable design and 8 power BS 1363 outlets make it a practical choice for organizing and safeguarding your electronic devices in any setting. Whether at home or in the office, the Belkin Connect surge protector is designed to meet your power and protection needs.
Versatile connectivity
Equipped with USB-C and USB-A ports, this surge protector meets the charging needs of a wide range of devices, from smartphones to laptops, ensuring your gadgets are always powered and protected. -
Comprehensive protection
Featuring a robust 900 Joules surge energy rating, this device safeguards your electronics against voltage spikes. The 'Protected' indicator light offers peace of mind, signaling that your devices are secure. -
Convenient design
With an integrated 2 m power cable and the ability to mount on the wall, this surge protector offers flexibility in setup and placement, making it an ideal solution for any home or office space. -
High-capacity support
Boasting 8 power BS 1363 outlets, this surge protector can handle multiple devices simultaneously, ensuring that you have enough ports for all your essential electronics.
 - Belkin Connect - surge protector - with USB-C and USB-A ports
 - Surge protector - external
- Cord Length
 - 2 m
- Input Voltage
 - AC
- Input Connectors
 - Power BS 1363
- Output connectors
 - 8 x power BS 1363 (surge) , 1 x 24 pin USB-C , 1 x 4 pin USB Type A
 - 2-year warranty
- Cord Length
 - 2 m
- Input Voltage
 - AC
- Input Connectors
 - Power BS 1363
- Power Output Connectors Details
- Surge Suppression
- Surge Energy Rating
 - 900 Joules
- Cables Included
 - Power cable - integrated - 2 m
- Equipment Protection Value
 - 60000 British Pounds
 - Wall mountable, on/off power switch, Power Delivery (PD), "Protected" indicator light
 - Limited warranty - 2 years
