Belkin Connect Surge Protector with USB-C and USB-A Ports
Quicklinx: J6HJWS00 Mfr#: SRB001AF2M
Hurry, only 2 left in stock!
£21.99 ex VAT
£26.38 inc VAT
The Belkin Connect surge protector combines functionality and convenience in a compact design. With a 2 m power cable, it ensures that devices can be easily plugged in from a distance while providing reliable surge protection with a rating of 525 Joules. This product comes equipped with USB-C and USB-A ports for versatile charging options, allowing multiple devices to be powered simultaneously. Wall-mountable features make installation straightforward, saving space and enhancing accessibility. An integrated on/off power switch allows for easy control of connected devices. Additionally, the 'Protected' indicator light signals that connected devices are safeguarded from power surges.
  • Reliable surge protection
    This surge protector safeguards devices against power fluctuations with its surge suppression feature, rated at 525 Joules.
  • Versatile charging options
    Equipped with four output connectors, including USB-C and USB-A, this device accommodates a variety of gadgets simultaneously.
  • User-friendly design
    With an on/off power switch and an integrated wall-mountable form factor, it simplifies the management of power connections.
  • Indicator light for safety
    The 'Protected' indicator light provides visual confirmation of the surge protector's operational status, enhancing user assurance.
  • Extended reach
    Featuring a 2 m power cable, it allows flexible placement, making it suitable for different room configurations.
Belkin Connect - surge protector - with USB-C and USB-A ports
Surge protector - external
Cord Length
2 m
Output connectors
4 x power (surge) , 1 x 24 pin USB-C , 1 x 4 pin USB Type A
Cord Length
2 m
Surge Suppression
Surge Energy Rating
525 Joules
Power cable - integrated - 2 m
On/off power switch, wall mountable, "Protected" indicator light, Power Delivery (PD)
Brand: Belkin
