Belkin CONNECT Pro Docking Station - USB-C - HDMI - USB4
Quicklinx: J797WS00 Mfr#: INC006vfSGY
£286.57 ex VAT
£343.88 inc VAT
Create the ultimate workstation with Belkin’s Pro Thunderbolt 4 Dock. It has 12 ports to connect your MacBook or Windows laptop to multiple devices, video, ethernet, and power through a single Thunderbolt 4 cable. Get up to 40Gbps data transfer speeds - that's 8x faster than USB 3.0. Charge your laptop and other connected devices simultaneously with up to 90W of Power Delivery. Immerse yourself in a smoother and clearer visual experience with top-tier video resolutions on as many as three additional displays. Included Thunderbolt 4 cable is compatible with Thunderbolt 3, USB-C, and USB4.
  • Access Up to 40Gbps of bandwidth
    With data transfer speeds of up to 40Gbps, Belkin’s Pro Thunderbolt 4 Dock is fast - up to 8x faster than USB 3.0.
  • 8K resolutions
    Connect your MacBook, Windows, or other compatible device to a smooth, vivid, and immersive visual experience. Get up to 8K resolutions for a single display or 2x 4K for dual displays. Triple display support available for select laptop models.
  • Thunderbolt 4 certified
    Tap into the next generation of Thunderbolt technology with Belkin’s Thunderbolt 4 certified docking station. Access all the power and speed you'll need for work, play, streaming, and more - even while connected to multiple peripherals and devices - all through a single cable connection.
  • 90W USB-C Power Delivery 3.0
    Belkin’s Pro Thunderbolt 4 Dock comes equipped with Power Delivery 3.0, delivering up to 90W of charging power to your laptop or other connected device. It also has a USB-C PD 3.0 port so you can fast charge a smartphone, tablet, or other device at the same time.
Belkin CONNECT Pro - docking station - USB-C - HDMI - USB4
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI
20 cm x 7.32 cm x 3.39 cm
USB4
Docking station
20 cm
7.32 cm
3.39 cm
Video
Max Resolution Details
8K - 30 Hz
USB4
Expansion Slots
1 SD Memory Card
1 x USB-C 3.1 Gen 2 - 24 pin USB-C , 2 x Thunderbolt 4 - 24 pin USB-C , 2 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB 3.1 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x audio - headphones/microphone - mini-phone 3.5 mm
1 x USB-C cable - 80 cm
90W power delivery
Windows 10, Apple macOS Big Sur 11.0, Apple iPadOS
Brand: Belkin
