Product
Belkin Cat6 UTP Snagless Patch Cable White 10m
Quicklinx: 2316WS00 Mfr#: A3L980B10M-WHTS
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Belkin High Performance patch cable - 10 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Molded, snagless
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568A
Plated Connector
Gold
Molded, snagless
Length
10 m
White
Connector
RJ-45 - male
RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
