The Car Vent Mount provides a safe, hands-free way to use your smartphone in the car. Vent Mount fits most large smartphones with screen sizes up to 5.5 inches with a protective case on. This cradle securely attaches your smartphone to an air vent on your car's dash for a convenient optimal viewing level - no suction cup or adhesive required. The Vent Mount rotates 180 degrees so you can use your smartphone in portrait or landscape mode.
Effortless rotation
Designed with an adjustable rotation mechanism, this car vent mount allows for seamless switching between portrait and landscape modes, ensuring optimal viewing angles for GPS navigation and hands-free calls. -
Universal compatibility
The Belkin Car Vent Mount is engineered to hold devices up to 5.5 inches in screen size, making it compatible with a wide range of cellular phones, from small to large, ensuring your device is securely mounted while driving.
- Belkin Car Vent Mount - car holder for mobile phone
- Product Type
- Car holder
- Intended For
- Mobile phone
- Suitable For Installation
- Car
- Screen Size Compatibility
- Up to 5.5"
- 5.5 cm x 5.9 cm x 3.3 cm
- Designed For
- Google Pixel XL; Huawei Nova, P10, P10 Plus, P8, P9; Samsung Galaxy S II, S III, S4, S5, S6, S6 edge, S7, S7 edge, S8, S8+
- Product Type
- Car holder
- Intended For
- Mobile phone
- Car
- Up to 5.5"
- Adjustments
- Rotation
- 5.5 cm
- 5.9 cm
- 3.3 cm
- Placing / Mounting
- Car ventilation grid
- Designed For
- Google Pixel XL , Huawei Nova, P10, P10 Plus, P8, P9 , Samsung Galaxy S II, S III, S4, S5, S6, S6 edge, S7, S7 edge, S8, S8+
