Belkin Car Vent Mount
Quicklinx: D2VZWS00 Mfr#: F7U017BT
Device Type: All
Type: Cradle
Product Range: Belkin
Product Model: Car Vent Mount
£21.48 ex VAT
£25.77 inc VAT
The Car Vent Mount provides a safe, hands-free way to use your smartphone in the car. Vent Mount fits most large smartphones with screen sizes up to 5.5 inches with a protective case on. This cradle securely attaches your smartphone to an air vent on your car's dash for a convenient optimal viewing level - no suction cup or adhesive required. The Vent Mount rotates 180 degrees so you can use your smartphone in portrait or landscape mode.
  • Effortless rotation
    Designed with an adjustable rotation mechanism, this car vent mount allows for seamless switching between portrait and landscape modes, ensuring optimal viewing angles for GPS navigation and hands-free calls.
  • Universal compatibility
    The Belkin Car Vent Mount is engineered to hold devices up to 5.5 inches in screen size, making it compatible with a wide range of cellular phones, from small to large, ensuring your device is securely mounted while driving.
Belkin Car Vent Mount - car holder for mobile phone
Car holder
Intended For
Mobile phone
Suitable For Installation
Car
Screen Size Compatibility
Up to 5.5"
5.5 cm x 5.9 cm x 3.3 cm
Google Pixel XL; Huawei Nova, P10, P10 Plus, P8, P9; Samsung Galaxy S II, S III, S4, S5, S6, S6 edge, S7, S7 edge, S8, S8+
Car holder
Intended For
Mobile phone
Car
Up to 5.5"
Adjustments
Rotation
5.5 cm
5.9 cm
3.3 cm
Placing / Mounting
Car ventilation grid
Google Pixel XL , Huawei Nova, P10, P10 Plus, P8, P9 , Samsung Galaxy S II, S III, S4, S5, S6, S6 edge, S7, S7 edge, S8, S8+
Device Type: All
Type: Cradle
Brand: Belkin
