Car Charger 2.1 AMP For iPhone 5, iPad mini, iPad 4th gen
Small but Powerful
It's here -- the car charger designed exclusively for the iPhone 5. Get unlimited play and standby time with the low-profile design that sits flush in your dash.
Charge at the Speed of Lightning
Charge your iPhone 5, iPad mini or iPad with Retina Display (4th generation) at the fastest possible speed with the smaller, more durable Lightning connector. It's reversible, which makes plugging it in easier than ever.
Know You're Charging
Green indicator light easy to see your device is charging.
Small, Compact and Easy to Insert and Remove
Low profile design fits easily in your dash. Rubber grips allows you to insert and remove your lightning car charger with ease.
Features:
-Ultra-compact
-Plugs into any car power outlet
-2.1 Amp/10 Watts
-4' cable with reversible Lightning connector
COMPATIBILITY
iPad mini
iPhone 5
iPod nano 7th gen
iPod touch 5th gen
iPad 4th gen
Small but powerful
Charge your iPhone 5 on the road with the Belkin Car Charger with lightning connector. Get unlimited play and standby time with the low-profile design that sits flush in your dash. -
Charge at the speed of lightning
Charge your iPhone 5, iPad mini or iPad with retina display at the fastest possible speed with the smaller, more durable lightning connector. It's reversible, which makes plugging it in easier than ever. -
Power up your iPhone 5
The lightning connector has a reversible design for quick and easy connections. -
Small, compact and easy to insert and remove
Low profile design fits easily in your dash. Rubber grips allow you to insert and remove your lightning car charger with ease. -
Know you're charging
- Belkin Car Charger car power adapter - Lightning - 10 Watt
- Product Type
- Car power adapter
- Black
- Output Connector Type
- Lightning
- Max Electric Current
- 2.1 A
- Power Provided
- 10 Watt
- Cables
- iPhone / iPad charging cable - 1.2 m
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone
- Enclosure Colour
- Black
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Output connectors
- Apple Lightning
- Power Provided
- 10 Watt
- 2.1 A
- Cables Included
