This compact 20-watt?wall?charger with USB-Power Delivery means fast charging for your USB-PD-enabled devices. PPS technology detects the connected device and negotiates the right amount of power needed for the ideal charge. Purposefully designed to be travel-friendly, this pocket-sized charger easily fits to any environment at home or when you’re out and about.
Fast charging for your iPhone
Fast charge an iPhone 12 or 13?from 0 - 50% in only 28 minutes. -
Fast charging for your Galaxy
Fast charge a Samsung S21+ from?0 - 50% in only 26 minutes. -
Universal compatibility
Power Delivery PPS?technology supports fast charging?of most USB-C PD-enabled devices. -
Keep your device safe
Get safe, reliable, and optimal charging with the integrated USB Power Delivery?3.1 chipset. Connect worry-free with built-in protection against over and under voltage, high temperatures and power surges.
- Belkin BoostCharge power adapter - PPS technology - 24 pin USB-C - 20 Watt
- Product Type
- Power adapter
- Designed For
- Mobile phone, smart watch, tablet
- White
- Output Connector Type
- 24 pin USB-C
- Max Electric Current
- 3 A
- Fast Charge Technology
- Power Delivery 3.1, Fast Charge
- Power Provided
- 20 Watt
- 2-year warranty
- Designed For
- Apple iPhone 14, 14 Plus, 14 Pro, 14 Pro Max
- Product Type
- Power adapter
- Designed For
- Enclosure Colour
- White
- Output connectors
- 24 pin USB-C
- Power Provided
- 20 Watt
- 3 A
- Equipment Protection Value
- 2500 US Dollars
- MFI, RoHS
- Limited warranty - 2 years
- Designed For
