Get a fast charge, up to 50% in around 36 minutes with sturdy USB-C to USB-C cables. Use them at home, in your car, or anywhere you need to sync music, photos, or data and charge your devices.
Tested to withstand 8,000+ bends, these USB-C fast charge cables are built with more strength and flexibility to use over and over again. This makes them ideal for easy placement in your bag to take on-the-go. They're also USB-IF certified so you can count on a great experience on any device.
Fast charging, quick syncing USB-C cable
Get a fast charge, up to 50% in around 36 minutes with sturdy USB-C to USB-C cables. Use them at home, in your car, or anywhere you need to sync music, photos, or data and charge your devices. -
Stay connected
- Belkin BoostCharge - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Sync and charge
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- White
- 2-year warranty
- USB-C cable
- Sync and charge
- Length
- 1 m
- White
- Connector
- USB-IF
- 2-year warranty
