Belkin BoostCharge USB-C to USB-C Cable 1m - White
Quicklinx: J7B0WS00 Mfr#: CAB003bt1MWH
47 In Stock
£5.23 ex VAT
£6.27 inc VAT
Get a fast charge, up to 50% in around 36 minutes with sturdy USB-C to USB-C cables. Use them at home, in your car, or anywhere you need to sync music, photos, or data and charge your devices.
Tested to withstand 8,000+ bends, these USB-C fast charge cables are built with more strength and flexibility to use over and over again. This makes them ideal for easy placement in your bag to take on-the-go. They're also USB-IF certified so you can count on a great experience on any device.
  • Fast charging, quick syncing USB-C cable
  • Stay connected
Belkin BoostCharge - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Sync and charge
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
White
USB-C cable
Sync and charge
Length
1 m
White
Connector
24 pin USB-C - male
24 pin USB-C - male
USB-IF
Brand: Belkin
