Get optimal charging speeds for both Samsung smartphones and iPhone with this USB-C charger. It's USB-C PD 3.0 certified with PPS technology, giving your device a safe charge with the right amount of power, all in a compact, travel-ready design.
Optimized for Samsung and iPhone
Get optimal charging power with this 25W USB-C PD 3.0 PPS wall charger. This fast and universal charging solution is optimized for both iPhone and Samsung smartphones, as well as other USB-C PD enabled devices. -
Dynamic power
Safely recharge your phone faster than ever with the intelligence of Programmable Power Standard. PPS technology enables the power supply to dynamically adjust its output based on the device it's connected to, delivering the exact amount of power needed for the ideal charge. -
The PPS wall charger is also USB-C PD 3.0 certified, which means it's safe, compliant, and meets required specifications for your compatible device. -
Compact and travel-ready
All the power and speed you'll need in a compact, travel-ready design.
 - Belkin BoostCharge power adapter - 24 pin USB-C - 25 Watt
- Product Type
 - Power adapter
 - 4.3 cm x 7.3 cm x 2.6 cm
 - White
- Output Connector Type
 - 24 pin USB-C
- Fast Charge Technology
 - Power Delivery 3.0
- Power Provided
 - 25 Watt
- Product Type
 - Power adapter
- Designed For
 - Mobile phone
 - 4.3 cm
 - 7.3 cm
 - 2.6 cm
- Enclosure Colour
 - White
- Output connectors
 - 24 pin USB-C
- Power Provided
 - 25 Watt
 - Programmable Power Standard (PPS)
